- 20 Feb 2009
- Ashton-Under-Lyne
In the middle of a new kitchen build, and I was planning on some LED strips for under the cabinets to give a bit more light on the work surface & reduce shadows (and probably also on the plinths, as I like the look).
Problem is, I can't seem to find any info online regarding what sort of brightness I should be looking for, or what lights would be good for this use (most seem to be for ambient lighting etc), and with options that would range from ~£30 to several £100s, I'm a little overwhelmed with options.
Has anyone done similar, and got recommendations?
Requirements:
Requirements:
- I'm not too fussed about RGB (may consider dependant on receiver positioning, cost difference etc), but might be good for the plinth lights.
- Dimmable option would be nice, so plinth lights can be tuned.
- They'll need to be OK to go round 90deg corners (either with a cut & corner join, or bent direct)
- Strings can be split & joined (I don't mind a bit of DIY if required), so gaps (such as around fridge/freezer) can be bridged.
- Will need to turn on in the last condition after turned off at mains, rather defaulting to "mode 1" etc (will be controlled from main light switch)
- Doesn't need to be smart controlled.
- Needs to be bright enough for task lighting on full brightness
