Man of Honour
- 17 Feb 2003
- Chelmsford
Nice tidy job..
OOOOO well would you look at that... that case is well nice! top job mate...
lol
hope your enjoying it mate
StevenG - thanks for the mention!
Looks sweet man. One thing I was wonering though, is on your tests for Far Cry why you had no AA at all? AA is the first thing I boost up on any game, and i'm a bit worried why you havn't with 2x 4870s.
Don't worry mate, it was the requirement for the Far Cry 2 benchmarking thread. In game i always use AA![]()
What FPS you getting ingame with AA and possibly Vsync on?
Would 120.2 be enough for that CPU or would that be not enough?
Where is the second rad, i can see one in the bottom at the front, is the other attatched to the roof, if so, how did you secure it there. Apart from that, WELL DONE
Yep the PA120.3 is attached to the roof using screws. Glad you like the build. If you have any specific questions around the custom case and where to get the cuts done - send me an email![]()
just thinking of getting a lian li pc-a70b or a pc-v2010B and basicly copying you compleatly. but some advice about genrally were to position the rad mounting holes would be great. Also apart from the powder coating, rad holes, and windows what else was modded in the case?
Apart from the above there are custom DDC mounts that have been added to the case. With regards to the case, may i also suggest the TJ07 - it seems to be the case of choice at the moment and IMO looks really easy to work with.
