**KOLINK CLASSIC AND MODULAR 80+ BRONZE POWER SUPPLIES NOW AVAILABLE FOR PREORDER **
OcUK Staff
26 Nov 2014
Stoke
Available for preorder now, we have the new Kolink Classic and Modular 80+ Bronze 230V EU Power supplies. The Classic and Modular series build on the original KL Bronze units from Kolink, adding improved internal designs including DC-DC conversion and a 120mm fan with fine tuned RPM curve for quiet operation. All the units now come with flat black cables as standard and a new fan grille. In fact the entire design of the PSU is a step up from the previous iteration, even if most of you hide it behind a PSU shroud ;) .
The warranty has been increased to 3 years for the entire range, and the wattages range from 400W - 700W wired, and 500W - 700W Modular. Stock will arrive in the next 10-14 days and represents another solid upgrade from Kolink.
Kolink Classic Power 400W 80 Plus Bronze Power Supply @ £36.95 inc VAT
Modern look with flat black cables, 348W and 29A on a 12V rail, 80 PLUS bronze certificate for high efficiency, ATX form factor with a length of 160 mm
Only £36.95 inc VAT.
ORDER NOW
Kolink Classic Power 500W 80 Plus Bronze Power Supply @ £39.95 inc VAT
Modern look with flat black cables, 444W and 37A on a 12V rail, 80 PLUS bronze certificate for high efficiency
Only £39.95 inc VAT.
ORDER NOW
Kolink Classic Power 600W 80 Plus Bronze Power Supply @ £44.99 inc VAT
Modern look with flat black cables, 546W and 45.5A on a 12V rail, 80 PLUS bronze certificate for high efficiency
Only £44.99 inc VAT.
ORDER NOW
Kolink Classic Power 700W 80 Plus Bronze Power Supply @ £49.99 inc VAT
Modern look with flat black cables, 648W and 54A on a 12V rail, 80 PLUS bronze certificate for high efficiency
Only £49.99 inc VAT.
ORDER NOW
Kolink Modular Power 500W 80 Plus Bronze Modular Power Supply @ £44.99 inc VAT
Modern Design, Semi-modular cable management, 80 PLUS bronze certificate for high efficiency, ATX form factor with a length of 160 mm
ORDER NOW
Kolink Modular Power 600W 80 Plus Bronze Modular Power Supply @ £49.99 inc VAT
Modern Design, Semi-modular cable management, 546W and 45.5A on a 12V rail, 80 PLUS bronze certificate for high efficiency
ORDER NOW
Kolink Modular Power 700W 80 Plus Bronze Modular Power Supply @ £54.95 inc VAT
Modern Design, Semi-modular cable management, 648W and 54A on a 12V rail, 80 PLUS bronze certificate for high efficiency
Only £54.95 inc VAT.
ORDER NOW
I have an old 4 core Xeon socket 1366 motherboard that i want to get up and running , i think will give the 400 or 500 classic a look. I dont want to spend on a high end premium psu for pc over 10 years old. are there any more budget cases coming out in the next month Kolink or Bitfenix
Plenty on the way from Kolink in the next few months at various pricepoints, some really nice stuff actually :)
Please ask them to supply more HDD mounts!
Have at least one with six, please. :)
Yeh, I know, I'm a dying breed that doesn't use SSDs.
Ive pre-ordered the 500w classic. Will be going in an old x58 PC which is assembled ready in the Kolink case that was on the Halloween deal. I will post pics up when it arrives and is installed.
@pastymuncher ; i can actually see you grimacing now. :)
@Kurgen You are a bad, bad man!! :D:p:D
At least they are matching most of the other budget psu warranties now at 3 years. Nice looking ribbon cables as well although it would be nice to see what gauge wiring they have used. The 12v rails are stronger on these units but they still have that disclaimer for 24/7 usage that no other manufacturer feels the need to state. It would be nice to see what temp these units were rated at as well. From the specs these could be HEC built units so we will have to wait for proper reviews to see if there are any quality in the internals.
What's the quality of these like? for the "lower" tiers like the 500W and 600W
It's a step above the previous iterations. Let's be honest, they are never going to challenge Super Flower or Seasonic, but I'd say they are dependable enough for up to mid range systems, especially with the internal DC-DC conversion improvements and better warranty.
