Kolink Continuum 1050W 80 - loud pop sound
30 Dec 2020
Hello,
I received a custom/prebuilt system 25th Apr 2020, with a "Kolink Continuum 1050W 80 Plus Platinum Modular Power Supply".
Recently the inbuilt power switch (on the back of it) made a loud 'pop' sound when I turned the system on. Now the PC turns on, but the power on/off switch on the power supply does nothing.
Does any one know my options for this, as it seems like it could be a safety issue? thanks!
Repost this in the customer service forum. You'll need to quote your order number. Hopefully OCUK will send you a new PSU and then you just return the faulty one.
