Having been a laptop gamer for the past 4 years, I have been a bit out of the loop in terms of GPUs.
I started paying attention again due to Cyberpunk 2077 coming out next year, and looking at where I can get good bang-for-buck.
This is a very rough guide, based on quick eyeballing of current average pricing (both new and second hand). Thought it might be helpful.
Based on this GPU hierachy (which I am sure most of you spit at
I will sort by best £ per performance looking at new Nvidia, new AMD, and a second hand card options.
£150 range
Second hand 1060 6GB (£130ish) : £2.5 per performance point (53 points)
New 580 (£160ish) : £2.8 per performance point (58 points)
New 1650 (£160ish) : £3.8 per performance point (42 points)
£200 range
Second hand 1070 (£200ish) : £2.9 per point (70 points)
New 590 (£200ish) : £3.3 per point (61 points)
New 1660 (£220ish) : £3.4 per point (64 points)
£275 range
Second hand 1080 (£270ish) : £3.2 per point (84 points)
New 5700 (£300ish) : £3.4 per point (88 points)
New Vega 56 (£280ish) : £3.6 per point (77 points)
New 1660Ti (£270ish) : £3.8 per point (71 points)
£350 range
New 5700XT (£375ish) : £3.9 per point (96 points)
New 2060 (£340ish) : £4.4 per point (78 points)
New Vega 64 (£380ish) : £4.5 per point (84 points)
£425 range
Second hand 1080Ti (£400ish) : £4.2 per point (96 points)
New 2060 Super (£400ish) : £4.7 per point (85 points)
New 2070 Super (£475ish) : £5 per point (94 points)
£500+ club
2080 upwards all scale as expected (ie getting way more expensive per point)
AGAIN THIS IS ROUGH
So Nvidia's 10x range do great in the second hand market on the cheaper side of the scale, but if buying new, AMD offers more bang for buck in the sub-£400 realm.
Hope this is useful to someone trying to figure out their budget options and appetite for second hand.
£150 range
£200 range
£275 range
£350 range
£425 range
£500+ club
AGAIN THIS IS ROUGH
