Kraken G10 help/info
Permabanned
6 Feb 2010
Barnsley
Will a Kracken G10 fit in it M-Atx Crossfire???
it looks like it may but i just can tell if a card with a fracken fitted takes up 2 or 3 slots
Not enought space from the pcb to the top of the bracket it is 45mm, with reference cooler fitted it is ~35mm so afraid not.
Fit a reference blower on the top and the G10 on the bottom will work.
You need a ATX mobo to crossfire with 2 G10's imo.
Or get the Corsair version, it "might" be a better fit.
What corsair version?
my top card hit 71C(OC'ed) when gaming so it can be done on a M-Atx board, i just want a quite pc
