I recently purchased the Creative SoundBlasterX Kratos S5 Soundblaster speakers, and as soon as they are on there is a hissing sound which wont go away, weather its just on desktop, or even watching videos/listening to music.
I have tried:
Plugging into a different socket,
Setting up in a different room,
Setting up without the computer plugged in,
I have W10, so it installed drivers automatically, but I still went to their site and reinstalled the up to date firmware and drivers.
Even bought a second pair to see if something was faulty,
Turned down all volumes to the lowest possible - and if its on the highest volume its insanely loud.
It also still happens when the volume on the mixer is muted.
I had a more simple Logitech set of speakers before which did not make the hissing sound, or if it did it was so quite that I was not aware of it.
I'm truly at a loose end here! and the hissing is so loud and I can't really find anyone else with the same issue, after going through the trial and errors.
I've stuck with headphones mainly for years now, is this common in speakers?
Any help or suggestions would be greatly appreciated.
Thanks
I have tried:
Thanks
