ks7500 and lost settings
24 Jan 2008
By Coffee cup...
Hi.
few days ago have noticed that my 7500 wont switch on with skyq remote as it used to and that when I play a video via chromecast that is connected to it it wont switch to that hdmi either...
have tried resetting the tv, and still no luck...now it even didnt recognized its chromecast...
anyone encountered anything like this ?
thanks
Sounds like it needs going in for repair , questioning whether the one connect box has gone pete tong or not. you got the BN number off the bottom of your box see if its one of the problematic ones. or something more a pita . you done a full reset via service menu ?
now you worry me :)
Yes I have done the reset without losing network settings...
will check BN now
@marcus_667 can you please advise on where I can check if my box is on the list of problematic ones ?
thanks
I can check at work for you , some earlier ones suffered bga issues, which were revised out
thanks! appreciate this
numbers from the one connector : SK 89 BN91-17814H HVTM 010129900852 1610 and vertical number 20160404
I only have owned it for a month...its 55ks7500
Can I just jump in and ask, how's the TV been generally apart from the current issue? Thinking of getting one.
Brilliant. Went for 55 as they didn't had anything smaller from ks7000 series and paid only £800 for new one :)
Cool, couldn't find any ks7000 local but managed to order a ks7500 for £860 so looking forward to it.
