YEs.. look at the very top portion of update manager and it will/should say that a new distro is available, Install ?
Be warned though... Last time I clicked that it created all sorts of problems. I ended up deleting the partitions and using a Gutsy Gibbon ISO I downloaded.
what I did was to move stuff I wanted to keep onto another drive/partition (NTFS) and using the new Gutsy ISO disk I then went into partition Manager and deleted the linux partitions including swap.
I then went ahead with the install and used "Guided - Use largest continuous free space " option when it asked.
Because it's a dual boot system it then asks for an account to import win stuff to.
and away it went.
Others might well choose a different path to upgrade. I chose that because I wanted the previous upgraded Feisty to Gutsy install completely wiping off the drive and a fresh installation of Gutsy putting on it.
