Lagging when recording gameplay help please
1 Feb 2025
UK
Hi
This is my first post so hopefully it makes sense.
My son has recently started recording Minecraft in OBS Studio along with a caption of himself in the corner on a webcam. The problem is that we are getting really bad lag.
I have copy and pasted my system details which I think is what you would need to help me?
Please help if possible
Thank you.
OS Name Microsoft Windows 10 Pro
Version 10.0.19045 Build 19045
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-UP9HL34
System Manufacturer Dell Inc.
System Model OptiPlex 7050
System Type x64-based PC
System SKU 07A1
Processor Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz, 3408 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Dell Inc. 1.27.0, 18/09/2023
SMBIOS Version 3.0
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Dell Inc.
BaseBoard Product 0NW6H5
BaseBoard Version A00
Platform Role Desktop
Secure Boot State Off
PCR7 Configuration Binding Not Possible
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United Kingdom
Hardware Abstraction Layer Version = "10.0.19041.5072"
Username DESKTOP-UP9HL34\User
Time Zone GMT Standard Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 24.0 GB
Total Virtual Memory 36.6 GB
Available Virtual Memory 28.8 GB
Page File Space 4.75 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualisation-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualisation Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
GPU is Intel(R) HD Graphics 530. I have just set the preference for this to high performance for Minecraft (but that was after I had already typed the below)
I wouldn't know if OBS is set up as you say. I will look it up in the morning.
I have just closed down EA as a startup app and it actually hasn't started glitching again yet....this is probably just coincidence and I will try again in the morning.
I tried task manager and it said that exploding a large TNT was getting just above 50% CPU usage straight after it exploded but came straight back down again.
OBS will not show in task manager while I am recording.....I guess this is normal though?
Thank you so far
I should think the integrated graphics would struggle to play the game and record, it is very basic, unless you mean the IGP is being used to record and another graphics card to play?
no, just one for all.
I did try and look up which graphics card was plug and play for this setup but it kept saying no Nvidia etc was compatible....
Thank you so far
yer using the CPU for game/GFX/OBS is not going to work
I am not so savvy....
I tried the well known part picker but it said none were compatible with my motherboard. Maybe I did it wrong
Depending on the size of your PC tower, it might only support low profile cards, which would restrict your choices a lot, but we'll find out soon enough.
If it has no power connector AND has to be low profile, then something like a used GTX 1050 might be your best bet. The 1030 doesn't have the encoding support so best avoided.
yer ne needs an SFF GPU with no power plug
i think given the GPU options he will still struggle with obs
Exactly which Optiplex 7050 do you have? Is it a tiny model (SFF), desktop (medium size), or a tower (bigger, floor-standing) model? From the model number and that you have 32 GB RAM, I think yours is the desktop model. If that's the case (ahem) then we may well be able to help. What you need to do is open the case and see if there is a spare power cable that splits into a 6 pin and a 2 pin connector. This is called a PCIE power cable. If you have one then your options expand considerably. Now look at the back of the expansion slots and see how big they are. Are they one thumb tall or two? If the former you're limited to what are called low profile cards.
Hopefully you have a PCIE power cable and a full height slot. In which case I can recommend the AMD Radeon RX 6600, which should cost you about £200. If your budget permits, look also at the Nvidia RTX 4060, AMD Radeon RX 6600 XT and RX 7600, and Intel Arc B570 and B580 cards. The RX 6600 and RTX 4060 are also available as low profile cards.
If there is no power connector then you are limited to 75W cards. Take a look at the Arc A380, Radeon RX 5500 XT, and GTX 1650 (not the Super).
Do note that all these cards take up two slots so do make sure that there is a second free slot!
If it's the SFF model with no power connector then it will almost certainly have to be single slot too so most GTX 1050 cards will be too big. Probably the best card would be an Arc A380 low profile for about £140. Heaven help us if it only takes a MXM GPU!
Morning all
So this is the inside. Any suggestion as to upgrade appreciated. I would be looking at hopefully rtx 40++. I think for future proofing and as I want the ray tracing and triple monitor ability.....
I sound like I know what I'm talking about far more than I do so please keep the technical stuff basic level?
From the picture the power supply is 180W and doesn't appear to have a PCIE power cable.
Additionally there is not a lot room beneath the PCIE motherboard slot (the long blue one)
Can't quite tell if the case is low profile or not but one option could be an RX6400 which are generally one slot and low profile.
