Lapping advice please (RSX chip on PS3)
Hey,
Long story, but after a bit of experimenting I've found that the RSX chip on my PS3 is very concave, and does not make any contact at the centre. This is causing the console to overheat and make a lot of noise, so I want to try and lap it to make it flat.
Now I've read a few lapping guides, and have a fair idea of what to do. The problem is all of these guides had a mobile item being lapped - i.e. the CPU/heatsink is moved on sandpaper which is taped to some glass. The RSX chip however is soldered to the motherboard, so my only option is to rub something against it whilst it is in a fixed position.
What sort of object could I use to keep the sandpaper (and chip I supposed) perfectly flat? And how would I avoid bit of metal falling onto the motherboard?? Any advice appreciated!
Cheers,
Suman
Hey,
Cheers,
Suman
