- 8 Dec 2012
- UK
Hi all,
I'm struggling to decide upon a predicument so honest advice is required. Please help me make the correct decision.
I recently purchased my dad a new laptop, specifically a Lenovo G710 i3 however it arrived with no battery.
So after Googling around I found a good deal. The one I bought has the following specs:
In the hardware maintanence manual - PDF on P26 it states:
However on P72 under the "parts" section it states the following batteries:
This web site I bought this battery from only lists 11.1v batteries for the "700" series.
For now I've asked my dad not to use the battery till I can determine if it is compatible or not. I've sent the below to the web site but haven't heard from them yet.
I've been reading the following links: http://www.ehow.com/info_12218810_ok-replace-10-volt-laptop-battery-14-volt.html ... and ...http://superuser.com/questions/440564/can-using-higher-rated-battery-damage-device
Q) Does having a higher voltage have any negative effect (i.e. is it safe to use) with the laptop?
I'm so confused on what to do ... ?
However the one that originally came with it was a L11S6Y01:Battery Type: Li-ion
Voltage: 11.1 V
Capacity: 5600 mAh
I'm really confused as this web site is stating it is for the Lenovo G700 series laptop.Battery Type: Li-ion
Voltage: 10.8
Capacity: 4400 mAh
3. If the voltage is less than +11.0 V DC, the battery pack has been discharged.
Note: Recharging will be continued for at least 3 hours, even though the
indicator does not light on. If the voltage is still less than +11.0 V DC after recharging, replace the battery.
4. If the voltage is more than +11.0 V DC, measure the resistance between
battery terminals 5 and 7. The resistance must be 4 to 30 KΩ. If the resistance is not correct, replace the battery pack. If the resistance is correct, replace the system board.
Battery,3S2P,6cell,4400mAh,48Wh,Sanyo L11S6Y01
10.8V 48Wh 6cellBTY Comm02
Battery,3S2P,6cell,4400mAh,48Wh,LG L11L6Y01 10.8V
Battery,3S2P,6cell,4400mAh,48Wh,SMP/S L11M6Y01
Dear Sir or Madam, on your web site site you are listing that all your Lenovo G700 series batteries (product IDs: 1003077, 1002989 and 1003139) are compatible. I bought the product 1002989 (5600mAh) for my dad's Lenovo G710 laptop. However 11.1v voltage on yours is different from the original Lenovo 10.8v. Can you please confirm that it is safe to use this battery with this laptop? According to the Lenovo hardware maintanence manual (http://download.lenovo.com/consumer/mobiles_pub/lenovo_g700g710_hmm.pdf) on P26 "If the voltage is more than +11.0 V DC, measure the resistance between battery terminals 5 and 7. The resistance must be 4 to 30 KΩ. If the resistance is not correct, replace the battery pack. If the resistance is correct, replace the system board.". Can you clarify that the battery meets the statement requirements between pins 5 and 7? If not please can I arrange a return as I do not wish to have a laptop being damaged due to over voltage from the battery. I have asked my dad not to use your battery for now until this information can be clarified. Thank you, Mr Slater.
