Laptop cleaning (safely)
Don't hoover it with a Henry, I tried that once at work. I ended up sifting through contents of the henry hoover to find the keyboard key it had sucked up.
people enumerating all the products they use on their car , don't realise a similar ecosystem exists for laptops
foam (aerosol) cleaner applied with q-tip is actually good for keyboards.​
vacuum cleaner and small brush between keys​
servisol for electrical connections usb/hdmi​
car shampoo(without wax/gloss enhancers) for screen​
bar soap for rubberized palm contact areas​
Nah, especially on the screen it can rub away the coating.
agree never alcohol - it doesn't remove grease from fingers as well as soap, kills screen coatings, and rubbberised palm surfaces.
