Laptop drive always on and seems slow
21 Sep 2010
Hi all,
I have an ASUS UX32A here with the 500GB + 24GB hybrid drive. The 500GB HDD seems to be always on, and the computer is quite slow with it.
I tested it with CrystalDiskMark and this is what it came up with:
Does this seem normal?
Cheers
Look in power saving options in windows,look in advanced and tick the hdd power saving,it should spin down when idle,
I think there's more to it than that. The computer should not be slow with a hybrid drive. Even if HDD power saving is enabled, I doubt it will speed up the computer, and it may never go into power saving mode if something is keeping the drive busy.
Maybe there's a rogue app or a virus/malware infection that's causing the problem. A hardware fault can't be ruled out, but there are some things to check first.
I'd check out the Task Manager (Ctrl-Alt-Delete). Goto the "performance" tab and click on "Resource Monitor". From there you can monitor CPU and Disk usage to see what might be causing the problem.
A full virus and malware scan might not be a bad idea either.
BTW. I'm not sue if the HDD in that laptop is a single hybrid drive, or a normal drive with a separate SSD used as cache. If the SSD is separate, maybe there's a driver or a setting that's causing the problem. I'm not familiar with this kind of setup, so maybe someone else can advise.
actually im not sure if it does power/spin down if its an os hdd?
my storage drives do as I hear them spin up when I access them
