It's here at last - my shiny new 160gb 7200.2 Momentus is in my grubby mits!!! (Thank you OcUK - all is forgiven - your customer support was excellent as always
Right - I'm trying to migrate my old 5400rpm samsung drive onto the momentus 7200PRM replacing it on my Dell m1710. I thought it would be a simple matter of cloning the drive in Acronis, ejecting the old one and plugging in the new one - job's a good'un.....
Right....
I won't go into the pain and suffering I went through to clone the samsung (nothing to do with Acronis which really is the simplest and friendliest piece of software I've ever used!) but suffice to say I did it - plugged in the new HDD and the machine goes through a constant boot loop - bios boot screen - blank screen - bios boot screen etc...
I can enter the Dell Boot menus (Hdd/Cd/NIC etc...) and the Bios. I can access the rather splendid Dell Diagnostic utilities (Someone needs to produce some of these for us overclockers - they are awesome
) - and nothing is wrong - sees the new drive, says it's fine.
I can't f8 into Vista Safeboot so I'm guessing it's not even satrting to load the Kernel.
Any ideas please?!?
The only thing I'll add is that when I cloned the drive I let it autoset the partition sizes (120gb->160Gb) - so all 4 of the Dell partitions grewproportionally (Main partition, recovery partition, +2 other odd partitions I assume are part of the system.)
I'm busy trying to re-clone it with the partitions remaining the same to see if that's what causing problems and then I'll 'simply' expand the main partition into the spare 30Gb once/if it works.
Anyone else tried this before?
)Right - I'm trying to migrate my old 5400rpm samsung drive onto the momentus 7200PRM replacing it on my Dell m1710. I thought it would be a simple matter of cloning the drive in Acronis, ejecting the old one and plugging in the new one - job's a good'un.....
Right....
) - and nothing is wrong - sees the new drive, says it's fine.I can't f8 into Vista Safeboot so I'm guessing it's not even satrting to load the Kernel.
Any ideas please?!?
that really wound me up - had to patch it out of the tin as the rubbish authoring software was incompatible with Vista - nice one Dell
