Hi guys,
I'm thinking about getting a laptop drive (after seeing how tiny they are
) and putting it in an external enclosure for use over USB so that i can carry more stuff around with me.
Seeing as i'd be using USB would i notice much difference in file transfers between these three speeds:
4200rpm
5400rpm
7200rpm
Or would they all be limited by USB and so i wouldn't notice a difference? I'm just wondering which speed to get as the 7200rpm ones are a lot more expensive than the slower ones.
Any recommendations on suitable caddies would also be great.
Cheers![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
![Eek! :eek: :eek:](/styles/default/xenforo/vbSmilies/Normal/eek.gif)
4200rpm
5400rpm
7200rpm
Cheers
