Laptop for Sketchup
14 Dec 2005
How much would I need to spend on a laptop to run Sketchup.
Will be using it in a workshop so wanting to stay basic
Out of curiosity...what would you need to spend before you're out of the really budget items? Best bang for buck kinda thing?
Thanks
Anything with a 1080p 15 inch screen would be ok. It is not demanding, and if you were really going to be pushing it's limits, I think you'd already know what rough spec you'd need?
Hope that helps, tricky without hunting for a product ID to link to as OcUK sell nothing that would be at all useful!
Good point about the screen....didn't take that in to consideration!
I loaded win 10 and bought a new battery for an old Dell 1545...Sketchup 2017 won't work but 2016 does.....get a message saying to try enable hardware acceleration when trying to run 2017. Got a win 7 driver for the intel series 4 chipset to work but no joy with sketchup 2017
Also the graphics in sketchup are blurry...so 1080p it is!
