Laptop memory help
27 Jan 2005
Letchworth Herts uk
Hi All i,m after some info regarding memory on a laptop , i,m not that well up on it , can anyone tell me what is the highest type is 6400 the highest ? feedback needed thanks :confused:
I have a Dell D630 Latitude Laptop 2GHZ
6400 is 800mhz, and the best timings you can get I think is 4-4-4, although I'm not sure on this.
Although looking at your laptop spec the max it can handle is 5300 RAM that runs at 667mhz.
thanks and is kingston a good make or what do u recommend ?
