- 4 Aug 2015
Hi
Just need some advice about a repaste on a laptop. I have a MSI GE75 8SF with a RTX2070 and think its probably in need of a repaste as it is getting very hot especially under load. Even at idle just sitting in windows the fans are ramping up. I've read numerous posts both here and on other sites about what to use as thermal compound but I was wondering what do i use for the VRM's and chips that are also covered by the heat sink. Most people that have posted about this laptop say there is some sort of thick thermal paste used by MSI for the VRM's etc and this turns out to be something like the K5 Pro paste. I'm assuming I can't use the same thermal compound as for the CPU/GPU?
Have you any other suggestions?
Thanks
Thanks
