I did consider it but it was only on one corner of the case and I used a manual hacksaw with a hoover pipe directly under to suck up metal filings.Haha sounds like you were very determined to fit it in the existing case. But didn't you remove all your components anyway before sawing the case?
Technically a larger mITX case can be one that also accommodates mATX.
Seeing as you're well past the boundaries of an ITX board in all directions I'd say that an ITX board limitation is irrelevant and if you need a larger case you need a larger case.
Just to let you know that whilst this case is quite a bit smaller in overall volume it’s longer and swallows the Zotac amp extreme 2080 with ease and an even longer card will fit too!Neo G Mini might be able to accommodate it, depending on your fans/radiator requirements:
http://metallicgear.com/products/Neo-G-Series-mITX
Glad you're liking it!Just to let you know that whilst this case is quite a bit smaller in overall volume it’s longer and swallows the Zotac amp extreme 2080 with ease and an even longer card will fit too!
It will also take a longer psu, another limitation of the bitfennix prodigy. It’s not as well built as the prodigy but has ticked all my boxes so thanks for the recommendation.
Downsides are it only has two ssd slots and the only cpu cooler that fits is an aio (bar an ultra low profile job). Cable management is fantastic compared to the bitfennix (that had none!) but I understand in relation to other cases the neo isn’t considered great for cable manager t.
