Laser Level
  • Thread starter Thread starter Deleted User 298457
  • Start date Start date
Don’t forget to get a tripod (or check they’re compatible with your tripod, if you have one)! They need to be within 2-3 degrees of flat in order to work. You can’t just pop them on a ladder step or a stack of books etc.
I have this…
Got for £30 a year or two ago and it’s been great. Specs have it as being every bit as accurate as the Dewalt one that’s over £100.
Battery life is good, accuracy is good and it connects to a tripod and also has a really strong magnetic mount too. For the money I can’t fault it.
I've had that one for years.. Bought from Screwfix If i recall..... However I dont think I paid that much......But could be wrong
There was a dewalt one that a mate had for setting out tiles that was much better though
There's a lot of chat about 30 quid ones but so far none have been. Which one?
Laser Level Green,RockSeed LV1G Cross Laser Level Horizontal and Vertical Points Rotatable 360 Degree Self Levelling Laser Level with Manual/Self-Leveling Mode IP54 Anti-Splash 1M Shockproof https://amzn.eu/d/0Xcdscw
This one and even with inflation rampant it is still £30! Used it for setting out bathroom tile and my kitchen can’t fault it.
Which one did you get in the end, the Bosch one is one I had shortlisted
You actually reminded me I had forgotten to finish this research off. Just went for what @a1ex2001 recommend as it was down another few quid with a cheap Amazon basics tripod.
I bought one of the Huepar ones after looking at this thread, and have paired it with a tripod I already have from a cheapo telescope.
Successfully used it to hang a picture. Although I do wonder whether I used it right. The line I needed was higher than the tripod will go, so I don't think I could use the self-levelling, as I required the unit to be tilted upwards to project at the right height. So I had to resort to using a spirit level on the top of the unit to gauge left-right level and then lock it in place. Then I used the level again against the line projected on the wall, just to ensure it hadn't moved while I was locking it in place.
It worked fine, but I can't help feeling there was likely a better way of doing it. So what is the 'correct' method when you need the line high up?
I bought this one, used it yesterday to hang a mirror (I know, excessive right), worked perfectly.
I have one that came with a little arm clamp so that you don't have to have a tripod set up all the time, handy if working in tight areas. I guess you can alwyas buy the arm separately.
