Laser Range Finders
I have one on my T72 i use it for shelling the local Chipshop chavs every saturday night.
Welshy said:
what are laser range finders? :confused:
I think they are those pointy thing on a gun or they one used for "painting" a target before the fighter jets drops a bomb or something like that.
Nope, that's a laser pointer.
A laser range finder funnily enough is a device that lets you work out how far something is away. You point the device at the target, press a button and it fires a laser at the target. The resulting reflection takes a certain amount of time, and therefore using some basic maths it'll tell you how far away it is. More advanced models can tell you the speed of a moving object, such as the Police speed guns. ;)
My answer is better :P
Yeah basically... lol
expesive steel tapemeasure.
Surveyors use them a lot they are useful if you measure things often
We sure do and they are the best invention yet for us poor guys who used to have to trail a dirty tape measure round buildings getting manky handling the things. They're especially great in big industrial sheds, accurate to a couple of cm over 100m or so. And not that expensive now either considering what they used to cost and how much time they save us.
Bill101 said:
they are accurate to within one foot!,that's 30cm. No wonder Estate agents like them for measuring room sizes :D
My folks use them for this purpose and it's just so much easier, and it's accurate to more than a foot :) Will have to dig out the specs on it, think it's a leica one.
Not their exact one but a quick google shows accuracy on the ones made for internal/small distances accurate up to 1.5mm.
http://www.crknz.co.nz/pages/survey/LTM/ltm.html
The ones that were accurate to a foot that the estate agents used to use were the sonic rangers were they not?
I use a Leica Disto same as this.
Accurate to 5cm over 100m :)
Only thing is they're not good outdoors so keep my tape handy for shop frontage measurement.
