Lastest CAT's with Control Panel??
They are all still made with the old Control Panel, just go get the FireGL set, its basically the Cat's with the old Control Panel instead of the CCC, or go and grab the Omega drivers as they support laptops. :)
So the FireGL will perform the same as the CCC set then?
The laptop has a 9700 mobility card inside.
**Edit**
No matter, I put the Omega 6.3's on.
