Lava Lamps
Permabanned
3 Oct 2009
North Wales
I just plugged one in, its been on for 2 hours...theres no movement whatsoever just wondering how long do these things take to start working?
I replaced the bulb, dont know what the wattage was but I have a 40w bulb in now. It feels hot around the bulb but not very warm at the top.
Is 40w enough juice?
Thanks
mine says MAX 40W on it so i think it should be enough, they do take a while to start the first few times, if you look at the bottom it should have melted slightly by now.
Is there a chance it might have been "off for too long" and its too solidified and wont work again?
Thanks freeman I'll keep watching
No I doubt it. It's a wax that should last pretty much forever unless it's been put through extreme hot (as in boiling) or extreme cold (as in frozen)
If it doesn't work after several hours I don't think it will at all. It should even work with a bulb wattage lower than what you have.
Just don't do anything stupid and try heat it up on a stove or something haha >.<
Mine has a 30W max but I see that now you can use a 40 watt clear golf ball SES bulb as a replacement.
ITS ALL JUST SUDDENLY STARTED WORKING
still a big blob at the bottom but some of its at the top now and occasionally small blobs moving up and down
