Evening Gents,
Yesterday I received a Samsung 226BW. Great in every aspect except 1. I have a constant flicker which is giving me a slight head ache. I've got a brand new machine and running an 8800 GTS, which only has DVI out ports. I previously had an LG 1720B which I used on this machine via a VGA cable with a DVI converter. That worked fine.
So I was initially using the DVI cable supplied with the Sammy on my machine. Hardly noticeable at first, but I was most gaming or watching movies. Now I've used the monitor for 8-10 hrs and have deffinately noticed it especially on my desktop while playing poker. I thought it may be static so I looked for the degause option, is none. Auto adjust is not available via DVI. So I plugged in my known go VGA cable and run the auto adjust. Still present but not as frequent. Monitor running at 60hz
Any ideas, suggestions or software you could point me in the direction of?
