Hi All.
I have one of the below TV brackets fixed to a solid brick wall which used to be home to my samsung 32 lcd tv.
On Saturday i went out and bought a new 42" LCd tv and am wondering if there is any reason why i cant use the same bracket.
the bracket itself is rate upto 40" and 68kg in weight.
the new 42" tv i bought has the same vesa mounting holes as my old TV and also only weighs 15kg ( same as my old samsung )
just to be sure i went to my local electrical superstore and checked all the 40 inch tv's in the range and they also have the same whole fittings on the back of the tv so is there any reason why i cant use the above bracket?
