LCD TV
12 Jan 2006
Northern Ireland
I use a DVI - VGA cable because my old monitor was VGA only. However my TV is DVI. I used one of those little adapter to make this cable DVI.
But my LCD TV goes off just before the windows welcome screen, everything works in F8 VGA Mode. If i change the resolution at all the screen goes off again.
If i connect up my old monitor i can get picture again for the tv until i switch it off. :(
What is the problem?
Have you tried dropping the resolution down to what ever the TV supports? I run and a 32" LCD TV and a Dell 24", If I set the resolution to high on my TV, it just switches off.
