LCD will not recognise HTPC!
20 Jan 2004
Bristol
Sorry could an admin move this I think it should be in the home cinema thread - thanks
Hi
I have Samsung 32” LCD (Sorry I can not remember the model as I’m at work – it’s a LE something or other) and I have it connected to my HTPC by HDMI.
The picture is excellent and it all works fine if I have the LCD switched on to the correct source before I turn on the HTPC.
However if I’m watching TV switch on the HTPC then changed the source all I get is a no signal message.
It also happens if I’m using the HTPC then switch over to the TV then try to switch back.
If I then restart the PC the LCD suddenly recognises the signal:confused:
Is there a setting I’ve missed as this is getting rather annoying.
Thanks
