Hey folks, over the last couple of days there's been a leak from upstairs and it's been dripping it's way down from the celling, it was only a little one at 1st but it got quite bad today so the water has been stopped.
Took a while to locate it as it was quite hard to see! Anyway i've located it down to this pipe going in to the toilet that gives it the water when you flush probably.
I'm pretty sure it's coming from the white plastic threaded bit.. is this a common problem and easy to fix?
Anyways it's been running straight down into the floor
So what do I need to do or get from B&Q or whatever or is it a plumbers job?
Thanks.
Thanks.
That screw didn't do anything, it just kept spinning.
