My watercooling is nearly ready to be leak-tested. I'm using 7/16" ID tubing so once it's over the barb it provides a pretty tight seal, I'm also using only o-ring barbs and metal clamps on the hose as well.
With this in mind is it essential that I do a 24hr leak test or can I be fairly confident that I won't have any leaks?
If I do have to leak test.. then I'm guessing I need to get my PSU working without the use of the pwr_sw on the mb (currently using a screwdriver to turn pc on
). The method is something to do with putting a wire inbetween a couple of pins on the 24pin line isn't it? I can't remember exactly but I know I've seen it somewhere!
Any comments appreciated
Felix
). The method is something to do with putting a wire inbetween a couple of pins on the 24pin line isn't it? I can't remember exactly but I know I've seen it somewhere!Any comments appreciated
Felix
