leaking pump?
17 Jul 2008
Potatoe
anyone ever had a dcc pump that's leaked out of the bottom of it where the circular piece of plastic is which sits below the spinny bit?
Yep. I hadn't done one of the screws up tightly enough. But then, if you do it up too tight, it cracks and then it leaks forever. Fun hey :)
it appears the o-ring hadn't properly made enough of a seal & liquid had gotten inside the pump and was slowly seeping out the bottom. phew no crack
I had mine leak twice from there. Once when I didn't tighten the screws enough and once when I overtightened them and cracked the plexi top lol. I have learned my lesson.
