Leaky water killed XP?
24 Feb 2009
Teesside
Hey. Got a lovely box of parts today, Dell Ultrasharp monitor, Lian-Li case and a few other bits including a Swiftech MCW-30 chipset block.
I installed some normal barbs onto this, ignoring the plastic ones it came with as they looked a bit rubbish, but the normal ones must not form a proper seal and I ended up with a lovely stream of feser down the middle of my mobo.
Anyway, left it an hour or 2 more leak testing with my PC drying out at the same time. Boot up, try to boot to XP and BSOD a few seconds after the windows loading screen came up. However, restarted it and tried Windows7 and it boots and works fine. Currently on it now and have been for a while.
Still wont boot to XP though... Anyone have any ideas? The feser was literally just down the middle of the mobo, pci slots were the only major thing to get wet, nothing near the hard drive so cant imagine it being the hard drive thats got damaged.
Any help would be great!! Thanks
Pretty much all system info needed in this I guess. Usually at 3.5GHz but turned it down a bit to see if it was just beein unstable.
Nobody any ideas on this? Just tried booting to XP again and same problem, Windows screen then BSOD. This is like, 4.5 hours after the leak now, everything seems pretty dry (PC been on about 3 hours so its warm as well to speed up drying)
Dont know, just flashes up, but like a tiny fraction of a second before it restarts.
Would try and get a photo of it but think it might take about 100 tries haha
F8 key during Start-Up and select
option - Disable automatic restart on system failure
Then check error message.
Can you get through to safe mode ?
Edit
Probably sounds like a waste of time and stupid but try turning the SATA cable round.
Was doing a bit of searching on net, fount couple of sites but not sure if allowed to link and am about to goto bed so can someone say if its ok to post a thread from another forum please.
safe mode does exactly the same thing, it was the first thing I tried last night.
What does turning the cable round do? wouldnt of thought it made any difference :confused:
have you tried a chkdsk? might be something daft like one of the XP files needed for boot is corrupt.
alternatively try repairing/reinstalling xp..
Tried changing the wire round, no difference
TB, I reset the bios to their standard settings and was no better, used the reset jumper on my mobo.
neil, I tried to run chkdsk but just flashes up a dos screen then nothing, guessing its meant to do more? Tried it with /F like the BSOD said, and tried it with my drives, /C and /X, still just flashes up then nothing.
Tried to boot from CD, but just doesnt recognise my disk, gonna borrow my mates later. Thought there might be somthing wrong with my dvd drive so tried booting from my Windows7 disk and that worked fine. Also, can put my XP disk in when Im booted into Windows7 and it comes up with a menu optional extra tasks I can do etc.
Just thought, if I use my mates XP disk, will it complain because its a different disk / maybe different versions (different service packs on the disk or somthing?)
Tried to repair using the XP disk, run chkdsk, said found an error when it got to 75%, ran it again and was fine. Still wont boot into XP though.
Is there some way to make it do an automatic check and fix sort of thing, thought I'd go onto repair windows and it would do it automatically, just kinda gives me a command line instead :(
Could the water have affected the PCI slots that xp checks when boots but windows 7 doesn't
Can you disable PCI slots in bios (sorry in work so can't check myself)
maybe water in the slot itself shorting pins (guess)
even if chkdsk repaired a bad sector or something the file that was sat on it may not be recoverable.. if you can get a bootable xp disc and try the repair option..
Do a repair installation of XP, rather than running the repair command line tool.
that will reinstall windows without deleting all your stuff.
have a google for "Reinstall XP without losing data"or "repair install XP"
Shouldnt be a problem with discs as long as you are installing a later version (installing SP2 over SP1, or SP3 over SP1 or 2). They CD data is all the same, its just the CD keys that windows checks.
