Man of Honour
Read above.
4ft.Yeah that's what I think it will be most used with, anyone know the operating distance?
For computer games yes, but this has other practical uses.
That's extremely cool.
I want such a system for "htpc" and being able to do more on a computer baed TV with no desk and no need for a cumbersome keyboard. Combine that with win8 metro. Hell yeah.
except you'll still need a desk to put the device on to have your hand right over the top of it for it to work.
Basicaly all you've made i na very tiring and inefficient keyboard.
That's rubbish, stick with kinetic or one of the other solutions demoed at CES (forgotten what it's called)
Lift your arm up and point at the screen every time you click something for the rest of the rest of today, see if your arm feels knackered by the end.
TV usage you don't do it constantly.
Imagine what the porn industry could do with this.
Mostly useless as your hand has to be directly above the device.
So that rules out home theatre systems, where this type of input might actually be of some use.
Why? Just have it on the coffee table in front of you, home theatre system was the first thing i thought of for uses around the home
So every time you want to change the channel/volume or pause, play, record etc. you'd have to physically move your entire body to position your hand over the coffee table and perform some gesture, rather than grab the remote control (which was likely closer to you) and press a few buttons, without having to lift anything but your arm.
If motion controls for home theatre systems ARE the future, they'll be based on kinect-like sensors that don't require you to position your body in a certain way to use them, just like some modern TVs are starting to come out with (Samsung Smart interaction technology)
