LED lcd cable output voltages?
HAz
HAz
1 May 2003
Torquay Devon
Anyone have a clue what the output voltage off each pin in a lcd cable are?
Just change a dc jack on a samsung r510 and the back light on the lcd isnt coming on now?
Not sure if it was working before but assume so. so annoyed!
I'm not familiar with the R510, I'm gonna take a stab im the dark and say 5v.
EDIT: Is this of any use?
They refer to an inverter, so it may be CCFL backlit as opposed to LED.
Thanks will check all voltages tomorrow, all I did was solder in a new jack plug, damn things.
I would just check the LCD connector is nice and snug, sometimes they need a little pressure for them to work.
I may be able to get some schematics if you need them, but they're not exactly easy to read.
yea i think its an inverter, just took screen out and its not LED its the old style cathod thing.
tested the cable voltages.
the inverter connector has 2 19v lines (constant) 1 3v (when on, 0v when laptop off) 1 0v (prob neg) and then 2 black 0v lines also prob negs.
and the inverter is giving out 0v's.
it did have a fuse on it which is ok but im pretty sure its dead.
when i keep the power lead in but turn the laptop off all vlotages stay the same apart from the 3v which goes to 0v which i assume is a switch live.
