LED Strip Adhesive
2 Jun 2013
Glasgow
Hi,
My LED strips in my PC case keep coming off.
Do you have any recommendations on stuff that will hold them on properly through the heat in the case?
Thanks
You can buy magnetic adhesive strips which would be better than using super-glue I suppose.
I have the NZXT Hue+ which have magnets built into the LED strips itself as well as having adhesive. The magnets work so well that I haven't even bothered to strip off the adhesive!
