LED strip weirdness. how?
28 Aug 2014
so i have 2 LED strips in my case both being the same bitfenix alchemy ones that hook up together. when i bought them they were exactly the same models and temp (XXXK - thats how you measure LED colour isnt it?).
so upon moving my PC to my new case i was putting them in and i noticed one of them had had the rubber over the LEDs melt or burn, it was sticky and was yellow. ages ago i noticed that my LED strips were not the same colour anymore. so how exactly would this happen?
cant figure out how to post image so will have to be link :(
if its too big delete it and ill just have to use the link.
I do recall slight flickering from them a while ago. Wouldn’t over voltage cause more of a problem than just that? The other strip wasn’t affected and they have always be connected to each other.
