Seoul p4s are brighter than crees, i imported them from germany.
I have just gathered all the materials for my project.
List so far:
3 x 28 to 25 mm copper 'fitting reducers' (these are the light bodies.)
3 X brass plumbing compression discs (heatsinks with thermal contact to copper bodies)
1 x 1000ma buckpuck constant current device to drive LED's
3 x Seoul SSC p4 u bin 240lm LED's.
3 x Fraen narrow beam 10deg optics.
1 water proof switch.
2 x 7.4v LiPo batterys (4000mah)
[mg]
http://img400.imageshack.us/img400/7987/dscf0822qr2.jpg[/img]
The optics fit perfectly in the copper reducers, and amazingly the brass heatsinks are snug fit on the elbow of the reduced diameter, at the perfect height for the led to sit.
[mg]
http://img355.imageshack.us/img355/9325/dscf0826vs3.jpg[/img]
Give me a couple of weeks and i will have constructed it
The LED's will be wired in series, controlled by a 5k pot
The 'heatsinks' fit snug in the thinner section of the reducer, and will be glued in with arctic epoxy (home made out of arctic silver and heat resistant epoxy). Then the copper housing will conduct the heat away.
