Legion 5i Pro 16" or Inspiron 16 Plus help me decide
26 Apr 2012
I have narrowed my search down to the following 2 machines. It will not be used as a gaming machine but I do need a decent GPU and a decent amount of memory (16gb). It will be connected to a external monitor/keyboard and mouse 80% of the time.
Both fall within my 1400 quid budget. Which would you choose or is there something I have missed during my search.
DELL Inspiron 16 Plus
11th Generation Intel® Core™ i7-11800H
NVIDIA® GeForce RTX™ 3060, 6 GB GDDR6, 60 W
16", 3K 3072x1920, 60Hz
16 GB, 2 x 8 GB, DDR4, 3200 MHz
1 TB, M.2, PCIe NVMe, SSD
LENOVO Legion 5i Pro
Intel® Core™ i7-11800H Processor
NVIDIA GeForce RTX 3060 - 6 GB GDDR6
16" - 165 Hz display - 3 ms response time - 500 nits
16 GB DDR4 (3200 MHz)
512 GB SSD
Many Thanks
You can get that exact Dell for £945 (using code DOPLUS14) in the Dell Outlet if you don't mind a refurbished one?
Thank you, In the end I decided to up my budget by 250 quid and went with a Dell G15 5521
Really wanted as much RAM as possible and with the newer generation Intel processor I thought this seem like a decent setup.
12th Generation Intel® Core™ i7-12700H
32 GB, DDR5, 4800 MHz, Dual-channel
15.6", QHD 2560x1440, 240Hz
