Lens Purchase - What Order Do You Use ?
Caporegime
18 Oct 2002
West Yorks
So i'm guessing a lot of people's second lens after their kit lens would be maybe a good prime like the 50mm or maybe a decent long range zoom if they were more into motorsport or nature.
But where did you go next ? Did you set about obtaining a "Holy Trinity" of focal lenth coverage, or did you end up with overlap of lenses doing similar focal lengths ?
This isn't so much of a spec me thread as I can find loads of suggestions online for what to buy, but more interested in what path you went and why :)
My advice to people is get the nifty fifty after kit lens. Inexpensive and very good.
Then replace the kit lens with something good... Save for the 17-55 f2.8 IS or the 24-105 f4. Yes its a lot of money, more than the camera in some instances... But will last a long time, both will do you proud and will live on the camera for 90% of the time.
After that you are into more of a 'What do you shoot/what do you enjoying shooting' scenario.. If landscapes then get something wider, sport etc then something longer.. If people then get something faster.. If plants/insects then get a macro lens.
Simples!
As for me:
(this looks complex, I did a lot of buying bundles at a bargain price, splitting and reselling.. This let me upgrade most of my kit for very little outlay)
Kit lens
18-135
50F1.8
20F2.8
75-300F4-5.6
17-55F2.8 IS
70-200F4L
24-105F4L (current)
100F2.8 macro (current)
14mm (current)
50F1.4 (current)
70-200F4L IS (current)
Obviously dont have them all anymore.. The only lens I regret letting go is the 20F2.8... Such a lovely bit of kit. Old, Noisy but took lovely photos
Also been through my fair share of bodies during the process:
350d
50d
5d2
1000d (to prove a point that the lens is all that really matters)
1d3
5d3 (current)
From all that the conclusion I came to is the lens is the most important part of kit unless you have a specific need for low light performance/high speed (sports).. Buy the best single lens you can afford.
This order
50/1.4
16-35L
24-70/2.8
70-200/2.8
135L
35L
85/1.8
85L
(After this point it was more what i want than need)
45/TS
100L
24L
50/1.4 A
100/2.8 L macro + 60D body only
10-22/f3.5-4.5
50/f1.8
120-300/2.8
Never had kit lens
All choices based on aps-c
I buy lenses for what I think I like so this was my priority
Macro - bugs, wildlife was my main interest so this came first
Architecture - always liked this so hence this second.. I haven't been many places to use it yet which is a shame
Distance - always liked birds and motorsports so bought 120-300mm.. Very expensive so didn't get it early
Portrait - never really interested me but for 50 quid I got nifty 50, probably only used it literally 5 times
Macro lens is on my camera by default
I tend to want to skip budget bracket for my areas of interest
So for macro I got a dedicated decent lens and also with other categories (except portrait)
As it turns out I might be doing some animal portrait stuff so my next purchase will be most likely
17-55mm f2.8
Or.. For my macro stuff
Dedicated flash for macro
It all just depends what you like to shoot. I got the X Pro 1 with the 35mm f1.4 lens and have only bought the 56mm lens 1.2 since, because they're both fantastic glass and I don't need anything else for them.
SLR/DSLR (Canon) I only have and use 24-70L f2.8, and 400L f4 because again, these two lenses do everyting I need to do with those cameras.
I bought a used camera which came with a Canon 28-90mm f/4-5.6 II rather than the expected 18-55 kit lens. I then went out and bought a Canon EF 50mm f/1.8 II.
Next lens will almost certainly be the Canon EF-S 10-18mm f/4.5-5.6 IS STM.
Started with 18-70mm
Added a sigma 70-300 and then a Sigma 10-20mm All bases covered and di everything I wanted Used all 3 lenses a lot.
Eventually added a 50mm f/1.8D, this was fun for a few months but was not touched since apart form at a wedding.
I then upgraded all the kit, 18-70mm was swapped for a 16-85mm. The wider angle made a huge difference, the lens was much sharpers, saturated and with more contrast. Likewise the Sigma 70-300mm was swapped for a Nikon 70-300mm VR with similar improvements.The 16mm end of the 16-85mm meant my sigma 10-20mm was rarely used except on special occasions. The 16-85mm and 70-200mm combo is my most favourite duo and my best lenses purchases considering quality, price, size, wight, and difference in upgrade.
I wanted a faster aperture telephoto so got a 80-200mm f/2.8 AF-D lens second hand. This was fantastic for portraits. I loved it, this was probably the 4th best new lens, but it always felt too short for wildlife so after a time I stopped using it.
I added a 35mm f/1.8DX - also loved it for a few months but then barely touched it except at a wedding.
I got a good offer on a 70-200mm f/2.8 VR so 'upgraded' my 80-200mm to this model. Waste of time really because as fantastic as the 70-200mm is, 200mm is just too short for wildlife and there is basically no difference between the older 80-200 and the 70-200mm.
I then added a Nikon 24-70mm f/2.8 since there was a pricing error which the website honoured. I was intending to buy a FF D700 but decided against it due to low pixel density and waited for a D300 successor (which still hasn't appeared so I exentually got a D800. The 24-70mm had minimal uses - the 16-85mm was just a much nicer lens to use with the 16mm end.
Up until now I was using my Nikon 70-300mm VR over the Nikon 70-200mm f/.8 VR because I needed the 300mm reach, and over the 70-200mm focal range there is basically no image quality difference worth worrying about, especially if you can stop down a fraction. So I then purchased a 300mm f/4.0 second hand. This is my 3rd best ever purchased and over the last 3 years by far my most used lens, used almost exclusively with the 1.4xTC attached. I've mostly taken a break from landscape photography because it is just too damned hard and requires much more time commitments than I have available.
I added an 85mm f1.8 as it was on a good sale and I had a B&H voucher to use. I have barely used this lens.
Overall all the primes are rarely used except the 300mm. The 50mm hasn't been touched since 2009, in fact I think i lost it somewhere during the last house move. 35mm used to come out occasionally for some family portraits.
Secondly, the most expensive lenses have mostly been the least used.
i also rarely shoot wider than 16mm crop these days - I just don't get the opportunities to go wider. Ultra wide angles need some very specific circumstances to make them work, very hard lenses to use.
I now have a D800 and use a 24-70mm as the every day lens. I also started using the 70-200mm a little more.
I still have all my crop gear as I am still not convinced by FF. Pixel density is important to me and although the D800 is about right I could probably sell it, but a D7100 and with the extra money by a super tele.
Eitherway a new telephoto lens is my most likely upgrade. 500mm f/4.0 is the dream but I might end up with something like the new Sigma 150-600mm Sport
Tamron 18-270 (bundled with 7D)
Canon 300mm f4
Sigma 70mm f2.8 macro
Canon 500mm F4 I
Canon 600mm F4 II
Edit: that's purchase order. 99/100 I go out with the 600 II on one body and a pack with another body, TC1.4x, tubes and either the 300mm or 70mm in it, usually the 300mm.
10-22/f3.5-4.5
50/f1.8
120-300/2.8
Never had kit lens
17-55mm f2.8
Basically the same as me, aside from I like landscapes too, which luckily a nice wide angle lens would fit the bill nicely. Need to figure out which to get for M43. I have 60mm macro, kit lens and 45mm prime for portraits right now.
Without wanting to sound euphemistic, I find that long is never long enough, wide is much more fun, and aperture is king.
My 12/f2 is pretty much glued to my Fuji. Occasionally the 35/f1.4 gets swapped on. The 18/f2 is a nice compromise for near-pocketability.
I've got a cupboard full of f2.8 zooms. Zooms and f2.8 suck :D
My first DSLR for me was about being able to get macro shots but it quickly developed into more :\ Here's how my addiction has progressed so far.
650d with 18-135mm STM - sold together to a friend
40mm F2.8 STM - it was cheap and new so why not? - currently selling
100 F2.8L - still love this lens
70-200 F4L - when I felt I needed more range and it was on a good offer - sold to MPB
10-22mm - When I wanted wider - still use this occasionally for landscape/architecture
100-400mm - When I realised 200mm wasn't enough - sold to MPB
70D upgrade from 650D :D
Sigma 18-35mm - My first lens faster than F2.8 and my first third party manufacturer lens
Sigma 120-300 F2.8 Sport - bought this to replace my 100-400mm but the IQ with extenders just wasn't the upgrade I'd wanted so finally...
200-400 F4L 1.4x extender - Love this
I wasted money buying cheap and buying twice or thrice :(
1000D with 18-55is
Sigma 18-200 OC. Meh, soon realised one lens doesn't cover it all.
Canon 1.8 50mm Still got never use.
Canon 1.4 50mm Awful, cheap nasty and not worth twice the 1.8 let alone 3 or 4x.
Canon 17-55 2.8 Worst mistake tbh, thought I'd always want to be on crop. Very good lens, I Personally should have gone 24-70.
Canon 70-200 MK2. I'd sell my wife before I sold this.
Canon 100mm 2.8 macro. I adore this lens for portraits of my son while he's young with perfect skin. Again I'd never sell this lens.
Canon 1.4 TC. If I had a quid for every time I needed this and found I'd left it at home, I could go FF right now :D
2010
550D with kit lens (18-55mm f/3.5-5.6)
Bought Canon 50mm f/1.8
2011
Bought Tamron 17-50 f/2.8 non-vc (Sold 18-55mm f/3.5-5.6)
Sold Canon 50mm f1.8 as I had to stop down to f2.8 to get decent results so no point keeping it
2012
Bought Tamron 70-300mm f/4-5.6 SP VC
2013
Bought Canon 17-55 f/2.8 (Sold Tamron 17-50 f/2.8)
Upgraded to Canon 70D (Sold 550D)
Bought Sigma 35mm f/1.4
2014
Canon 70-300mm f/4-5.6 L (Sold Tamron 70-300mm f/4-5.6 SP VC) - long long overdue but didn't have the money.
Sold Sigma 35mm f/1.4 (wasn't getting enough use)
Bought Canon 85 f/1.8
Bought Canon 28 f/1.8
Bought Canon 50 f/1.4
Bought Canon 5D Classic.
Usually I'll use the 17-55 f/2.8 and the Canon 70-300mm f/4-5.6 L on my 70D and the 28, 50 and 85 on my 5D. No point using the zooms on the 5D because one won't work and if I'm using the 70-300mm I need reach so crop > FF in that regard. Not really getting on with the 28mm so that might go but otherwise I am happy with the setup, rather than wanting to swap the 5D with a 6D or 5DIII but that's more money that I don't want to send. I am pleasantly surprised with the IQ from the 5D and I really enjoy using it.
dannyjo22, I really like my Canon 50mm f/1.4 and it stays on the 5D most of the time, it's plasticky but I've never been let down by the performance of it. Much better than the 1.8 IMHO.
started off with
nikon d5100 with 18-55mm kit lens
50-200mm f4-5.6
50mm 1.8D (current)
50-300mm f4.5.6
changed body to nikon d7100
80-200mm f2.8 (current)
10-20mm f4-5.6 sigma (current)
the 80-200mm is usually always on the camera although looking to get a f2.8 to replace the kit lens
Canon 450D + 18 - 55 kit lens (need to sell)
Canon 70 - 300 f4.5 - 5.6 (need to sell)
Canon 50 mm f1.8 (sold as i didn't use it)
Canon 100 mm f2.8 macro
Canon 5D mk2
Canon 70 - 200 f2.8 L + 1.4 extender
Canon 24 - 70 f2.8 L
Next (whenever that will be)
Canon 16 -35 f2.8 L / Canon 1dx (probably wont happen) :(
