Lens question from a novice
13 Nov 2012
I'm a beginner so sorry if my terminology is off.
I have a D3200 and have just purchased a Nikon 50mm f/1.8D from these forums, was cheap so thought I'd give it a go.
Lens is working fine and giving good results but my camera will only let me take a pic when the lens is locked at f22. If I change aperture on the lens the camera warns me 'Lock lens aperture ring at minimum aperture (largest f/-number)’. Does this mean I can only ever shoot at f22 or is there a way around it?
It’s not a massive problem if I can’t shoot at a different aperture as the results I get at f22 are good for what I am using it for, but just wondering.
Cheers
With modern cameras the lens needs to stay locked at f22 on the aperture ring and the camera will electronically control the aperture depending on what you've set in camera. The aperture ring is only used on older cameras without electronic control.
Ok thanks, that makes sense.
Am I right in thinking that I will only get a very short depth of field on all images then? As that seems to be what I am getting no matter what the camera aperture is set to.
No, the lens will work normally. Lock the lens to f/22 and forget about it, the camera will control the aperture.
It is a shame you can't use the aperture ring on the lens but it hardly matters.
Your biggest issue is that lens simply won't auto focus on your camera.
There is a custom function on some models that allows you to use the aperture ring instead of the camera dial. On my D810 its under f9 customize command dials > Aperture setting.
