Lens Question
6 Apr 2010
Cambridgeshire
About 2 months ago I bought a Canon M50 MkII, mainly for streaming and the clean HDMI output, however it has actually made me get out and about again with the camera and I am really enjoying it. I just have the standard kit lens right now (15-45mm) and I am wanting to expand my lenses.
I really like macro photography out in the wilds (fungi, leaves, berries, small creatures etc) and so I have been looking to get a macro lens but I am torn between options. I have thought about buying the 28mm EF-M macro, however I am also tempted to purchase the EF to EF-M converter and go for the Sigma 105mm instead. The EF to EF-M converter allows me to use my wifes lenses and borrows friends lenses when I am able too.
My question then, for £500(ish) want solution would you look at?
Alternatively, I have been thinking about just sticking with the EF-M range, albeit small, and getting the 28mm Macro but also picking up the 22mm pancake lens for some fun also. Unsure on the quality of this lens though and again, if I bought the EF to EF-M converter I could also when funds allow get the 50mm 1.8 that everyone raves about.
If my ramblings have made any sense, what are your thoughts?
If you're after anything that moves under its own power then you need to be a decent distance from it to avoid scaring it. A 28mm lens does not give you any separation from the subject worth a damn. The Sigma 105mm will do this and is an excellent lens plus, as you say, the adapter gives you access to a much larger range of lenses.
Got to admit, I bit the bullet today and bought the canon converter (£70 second hand, but looks brand new) and a new 50mm 1.8. I also pickup the Sigma tomorrow.
Now only if it will stop bloody raining!!
The best Canon Macro lens is 100L F2.8 IS USM Macro lens is bloody sharp !
I even use it for Portrait work when I select a different focusing distance selector.
Buy a used one which go for apx £480-£600
I am really happy with the Sigma to be honest, and if I wanted to use the Canon 100L my mum has it so its always around to borrow if needed. :)
