I'm trying to work out a price to build a garage/workshop structure, for a new house we're looking at. I was initially thinking of a timber frame but have been looking more into blockwork to see how the costs compare.
In theory the structure will be around 8m x 3m (ish). Probably split into 2 sections, one for a workshop and possibly one for a cinema room or gym. Planning permission will be sought if needed. Although i'm thinking walls at 2m and then a slight pitch to the roof to stay under 2.5m. Just need to work on drawings to decide whether the pitch would be enough for such an area.
The plan would be to take my time, build it myself and learn some good skills. Possibly taking a 2 day bricklaying course to learn a few tips. Although youtube also comes in very handy.
Obviously the foundation/sub base will need to be much thicker if making from concrete blocks due to the weight.
I'm also trying to decide the best size of blocks to use. I presume if i was to go single skin, i'd be better using 440x215x215 blocks as they'll be much more sturdy. But if i went for 140mm blocks and built piers every 3m then would that also be suitable?
Also, whats best between solid dense blocks, hollow blocks and thermalite?
I imagine i will have LOADS of questions so going to use this as a sounding board thread. I did try reading a few others on the forum but they're old and all pictures have gone
I've just done a block calculator and it's suggesting that for my structure, i will need 434 215mm blocks. Does that sound about right? That would suggest the build for the main structure would be about £2k
My theory is to aim for around 6-7k in total, if doing most of the work myself (bar plastering!)
The dad of one of the house sellers is an Architect. Wonder if he'd knock me up a drawing for free if i bought their house!
, at least not without having to rule out other options first
