- 8 Apr 2015
- Normally in the car
I have requested from HQ clarification as to whether the 32UD99 has local dimming - once I hear back I will advise
This:
And as taken form that tftcentral article I linked, Badass really started the paragraph of best:
The LG display is nowhere close to being a "true" HDR monitor, it is essentially just a basic monitor with the above you have listed to get the "HDR" badge/selling point. IQ etc. will be a bit better than a standard monitor but it is not going to be anything like a "true" HDR monitor. To fully achieve the benefits of HDR, you need some kind of local dimming, which as far as we know... the LG does not have.
The upcoming asus 27" 4K 144HZ monitor is the only monitor so far to have the following to make it close to being a proper HDR monitor:
- full array local dimming zones and 384 of this lovely tech. That is around the same as what some of the lovely big expensive TVs have and they are 50+"
I have seen numerous fake "HDR" TVs and they look barely any better than a normal TV.
I think the frustration is that we have UHD Alliance Premium logo TVs available for under a grand but PC uses are being fobbed off with just HDR ready monitors and charged over a grand.
The issues though are the specs that are ok for a TV wouldn’t fly for a monitor (otherwise you would get a TV), notably response times (looking at minimum of 26ms) and the size of the market (TVs everyone, Monitors select few).
Not saying it isn't egregious that a 55" UHD TV with its own damn computer built in can be had for less than a 4k 'HDR' monitor. Early adopter tax.
http://www.tftcentral.co.uk/news_archive/37.htm#auo_samsung_roadmaps
We know that AU Optronics are investing in research in to HDR supporting backlights as a priority. These start with global dimming options with only 1 dimming area, and are of course the most cost effective. Edge Backlight Unit dimming with 8 or 16 areas are also under development, while the full flat direct backlight unit with >300 dimming areas is the best option for true HDR. Have a read of our HDR article for more information about this. AU Optronics are also establishing the feasibility of offering a full array (>300 areas) backlight for curved screens but it's not yet in development.
Panel wise, AUO will offer various HDR display options. The edge backlight options will come in flat 32" (2560 x 1440) and curved 35" (3440 x 1440) sizes and are based on VA panel technology. They will offer 8 backlight areas and a colour space of DCIP3 >=90%. 400 typical and 600 cd/m2 peak brightness is provided and these panels are forecast to go in to production in Q3 2017.
AUO are also now working on a 32" HDR IPS-type AHVA panel, with similar features as the asus 27" 4k 384 full array local dimming. A 3840 x 2160 ultra HD resolution, 384-zone backlight, HDR support, DCIP3>=95% and 400 - 800 cd/m2 brightness. This 32" version is expected to go in to production in Q4 2017 so is some way behind the 27" model. No confirmation on refresh rate of the 32" panel, although we don't believe it will be high refresh rate sadly as it is not listed in their gaming panels, whereas the 27" version is.
Samsung are investing in a couple of unique and interesting options as detailed below. Part numbers are not known at this stage:
- 49" mega-wide panel - this panel will offer a massive 49" size, in a 32:9 aspect ratio which Samsung are referring to as a "Grand Circle" format. We knew about the plans to produce a panel like this back in January 2016, but more details are starting to emerge now which is good news. These are the current specs but could have course change between now and mass production. The resolution will be 3840 x 1080 (referred to as DFHD = double full HD). It will be a VA technology panel with a 1800R curvature and a 3-side frameless design. The panel will offer a high 5000:1 static contrast ratio which is pushing the CR beyond current Samsung VA panels in fact. Perhaps most interesting is that the panel will apparently support a 144Hz refresh rate, along with options for AMD FreeSync and NVIDIA G-sync. The panel is due to go in to mass production around September 2017
Do you know when this will be on sale in the UK?don't get me wrong, global dimming isn't ideal either in my view, but until OLED monitor comes out (or someone decides to do full array LED) this looks like the only viable option, as I know I wouldn't want that halo effect
it is my understanding that to avoid the halo effect that comes with local dimming on LED, our 32UD99 will have global dimming
as LED monitors are not full array (as this would be far far too expensive), global dimming is the only way forward without that halo effect currently
Good good I look forward to the reviewsPotentially May - albeit a panel shortage on high end 4K and 5K screens isn't helping
