Look, what I'm saying is only tongue in cheek but personally if I couldn't wall mount the TV I wouldn't buy a TV that was designed specifically to be wall mounted.
Easy said but does anyone offer the newer evo panel in a 'stand designed' package? I'm not sure anyone does yet, so if you want the new panel tech, the G1 is your only option anyway - I wouldn't avoid buying the G1 if I wanted the evo panel just because it was packaged up with wall mounts instead of a stand.
What you're effectively saying is "If I couldn't wall mount the G1, i'd rather buy a different model with the older screen tech in it rather than put the G1 on a stand"
