Thanks, will have a lookCheetah mounts are good quality and affordable and go up to 65-80 inch.
Got a 47inch tv on a articulated mount one for £35 or can get the standard tilt one for £12
yes thats all i need really, looked at some that can pull away from the wall for easy access to cables but I think for a tv this size I'm better off static, less chance of tilting I thinkWhat kind of mount are you after?
I bought a Sanus one which has been great for me and is really slim, but it's just flat static mount.
looks like what im looking for, is that the variable tilt one from the rain forrestPut my dads 65 b7 on the wall with a Ross Black Fixed TV Mounting bracket 36-63.
Was an easy enough thing to do, just lift the TV onto the bracket on wall and just hangs there, have decent wiggle room side to side before you secure it down as it just hangs on a rail.
Not sure If am allowed to give links but its the 2nd option on google for £30.
The extra 2inch doesn't matter lol
If you want tilt the same one is available (with tilt added) for £40 from same place.looks like what im looking for, is that the variable tilt one from the rain forrest
duh, just read fixed
ROSS BLACK TILT TV MOUNTING BRACKET 36-63
