LG Flatron W2261V-PF Problem
15 Oct 2010
So i just bought the monitor---> http://www.overclockers.co.uk/showproduct.php?prodid=MO-075-LG&groupid=17&catid=949&subcat=
As soon as i turned it on and all the drivers were installed the screen was colours were red and variations of red. When i tried to change the rgb settings i saw that all of them (red,gree and blue) are set on 50 but when I tried to change the settings for green and blue nothing happened. Only red works, i can make it more or less red. Whats the problem? Why won't it work properly? :confused:
EDIT: am using the vga port
Is it all red when booting through the BIOS screens or just in Windows?
I would try either using a different VGA cable or try the HDMI and DVI connections.
If it's still all red then it suggests the monitor or your graphics card is borked.
Perhaps you don't have the options to adjust green and blue because none of that colour is being sent to/received by the monitor.
