...any info on the possibility of a FreeSync 2 monitor with this panel (LM375QW2) ?
I am wondering about this too. Why put G-Sync module when:
1) Makes the monitor a lot more expensive as the G-Sync module costs $100-$200 by itself
2) NVIDIA supports Adaptive Sync, meaning you can make the monitor FreeSync 2 with HDR1000 and let NVIDIA qualify it as "G-Sync compatible", that would make the monitor cheaper = better sales as both AMD (and Intel entering the graphics market next year) have support for Adaptive Sync (/FreeSync).
3) Since FreeSync is supported over HDMI 2.0, this gives flexibility. G-Sync is only supported using DP. Also - who would buy this, if NVIDIA suddenly plunders? It will be 2 against 1 next year.
Honestly, LG should stick to the open standard Adaptive VRR.
G-Sync modules are currently
WORTHLESS JUNK - G-Sync does NOT work with every game out there (example: Path of Exile). G-Sync has issues on some games killing FPS (The Division, Witcher 3, some MMOs). Face it, NVIDIA has hardware support for VRR - when it works it's great, but when it doesn't work - why spend the extra $$$ for NVIDIA GPU and a G-Sync module? If NVIDIA's G-Sync modules are to become the norm, then they have to be FREE, work with EVERY application/game out there and work flawlessly - and that's not the case!
I will not be buying a monitor with LM375QW2 panel if it has no support for Open Adaptive Sync. If LG decides to release one with FreeSync VRR, then sure, as long as the price is reasonable.
