LG27GL850 causing fault light on MoBo
29 Jan 2017
Scotland
Recently just bought an LG 27GL850 2 days ago and yesterday all was grand until today my white VGA debug light stays on the whole time after booting. (Very annoying as my PC is on my desk and I can literally see it in the corner of my eye) It also isnt allowing me to access the BIOS from boot or through windows. I have identified this as the monitor as I plugged in my old one using the old DVI cable I was using originally with this. No lights, no issues accessing BIOS either. LG is using Display port 1.4.
Kinda bummed honestly cause I absolutely love the monitor, makes my old zowie 24 inch 1080p one look like crap... Anyone else had issues like this before? Is this a simple settings issue or will i have to return it?
Monitor works as it should connected via HDMI, however it is limited to 100Hz opposed to 144Hz through DisplayPort. That is no good to me. So I think I will be returning this monitor.
It’s my understanding that’s a limitation of hdmi rather than the monitor. I thought 144hz was only achievable over dp? Apologies if I’m wrong.
144hz is possible over HDMI, I'm using one right now as a 2nd monitor from my laptop and its at 144hz plugged into HDMI1. I do remember it requiring some tweaking though, cant remember what sorry!
**Edit** Ah yes, you have disable active sync over HDMI to get 144hz. This is fine for my laptop use as its just for work. I have my gaming PC plugged in via DP and get 144hz with adaptive sync.
So update on this, ran this past my uncle to see if he had a spare cable and he pointed me to nvidia firmware update tool. I still have a GTX 1080 at the moment and there is an update available for these to run display port 1.3 and 1.4. Installed the driver and hey presto, everything is fixed. Assuming it was locked to Display port 1.2 beforehand which was causing all the problems.
Well that was a simple fix glad it’s sorted, a reminder to us all to keep on top of driver updates or at least beware of what they contain.
