LGA 1150 Pin Out Map/Diagram
31 Aug 2011
Hello All,
I have a motherboard that has some damage to the socket pins, in particular two pins are missing. I have searched for a diagram that will give me an idea of what the pin is used for and if it might still work if I bend back the rest of the pins. I see colourful diagrams for LGA 1155/56 etc but none for 1150.
Can anyone point me in the right direction?
Paul.
you can try the cpu anyway,it simply wont boot if its a needed pin that's broken off,some are reserved/unused pins
idk the layout for 1150,i did find one for 1155 though,my z68 board has a missing pin yet works fine
what board is it? gryphon;)?
Hi wazza,
It's an asus maximus vi formula. I stuck a CPU in and the led shows error 55, no memory installed.
Damn it. Can't believe it's destined for the bin with no chance of repair.
Thanks for the info
Of course it's repairable, just email ASUS and tell them you broke the board and would like it fixed.
They'll charge you to repair the socket but it can be repaired.
they wont,even if you offer to pay:( been there done it
Hi wazza,
Thanks for the info
did you try just one ram stick installed? test each slot one by one,you might get away with just two ram slots working
Wazza is right, I did contact asus and they said they do not offer a repair service.
Jam in you might be spot on there, depending on which way you have it, pins are missing on the lower left corner.
wazza I did not try a single stick, had two and tried a1/B1 then a2/b2.
I'll give that ago, thanks guys.
I've heard people had success with jamming a wire into the broken pin hole. If you can bend a tiny piece of wire into a hook shape and stick the unbent bit down into the hole. Copper and gold have very similar conductivities so this shouldn't pose too much of a problem. It's a tweezers and magnifying glass job though.
Yes I too found a video where the chap spoke about inserting something in to the socket hole but he did not actually show how he did this or go in to detail.
I imagine it would be a little tricky because the inserts may move or just swivel around.
I guess it's worth a try as I have nothing to lose.
Thanks john.
You'll have to be good to wedge a piece of wire in there and stop it moving,you can buy conductive glue and glue it in place but its very hard to do as everything is minuscule
Hmmm ok, not sure I want to lose the processor as well.
Yes I did try to find some shops that offer a replacement service, I will have to have another look. If the price is right, I will go for that after trying individual memory sticks.
Thanks all for your help/comments.
