Lian Li Case Side Fan
30 Mar 2007
On The Earth
Just managed to get me the Lian Li Side Blowing Fan unit from a other supplier..
Ive been looking for one of these for a few weeks now as they supposed to be really good for removing the hot air out of the case from the gfx cards..
Will post results when I get it tomorrow..
Hopefully it will knock a few degrees off me case temps
Glad you made this thread as ive been after one of these for ages as i couldnt find anywhere in the uk that stocked them,until now that is.
The fan is best set as output, I tested it on my previous card, had a 120mm blowing into the case and it messed with the airflow and made the temps higher than they are if you have it on removing the air.
InvG
Just got mine put in and have it blowing air onto my gpu,its nice and cool this morning but the temp of my oc`d GTS never went above 60c in-game.
It`s currently idling at 48c,it`s knocked my cpu temp down a degree or two also so at the moment i`m happy with it.
